FWIW, my novice concerns would be quality of design (is it cast? Will it crack under rotational stress? Is plastic pliability better than having a rigid metal rotating that fast if it hits something?), true measured same or higher airflow at all rotational speeds, and the balance (for example, if it stressed the bearings by being off-balance, that could have long-term repercussions.)
But, hey, I am a novice when it comes to these things, so I hope others post too!
Z
