Performance Clutch
HotCarl300zx
Car: 300zx Na
300zx TT
Hey guys I am putting my 300zx Na motor back in my car some time in the next 2 weeks :) and I am going to replace the clutch while the trans and stuff is out. So im looking for a performance clutch here are some of the performance ive done to it.
Ud pully
headers
cat back
testpipes
port and polish
ash ecu
pop charger
1 pice drive shaft
Might be doing water inj for fun
- So i want a good clutch that i can rely on
300ZXttZMAN
You are working on your NA Z correct? I see that you are talking about putting the NA engine back in your car but you are also talking about water injection. :confused:
Is your NA engine stock? If so water injection would be waste IMHO.
HotCarl300zx
Car: 300zx Na
300zx TT
ya i am working on Na what i meant to put was Nitrous lol (will get from old race car i have) and NO my engine is not stock its bored out its got forged pistons and rods, also have performance cams and like i said port and polish so it might be a little stock
DCaff300ZX
Car: .
1993 CRP TT- Modified
Putting a TT clutch and flywheel in will give you more clamping force (enough for 300HP) than your NA setup, with the only catch needing to maybe grind some on the bellhousing and/or shim the starter.
IIRC the TT clutch has about 200 lbs more clamping force, I had this done when I 5 speed swapped my NA.
HotCarl300zx
Car: 300zx Na
300zx TT
my buddy has a tt trans sitting so i might just throw it in and get a new clutch then but still want to see what clutch people would say
z32loverboy
Car: 1990 300zx CRP N/A 5 Speed (wreaked, now a shell) SOLD
1993 Slicktop CRP N/A 5 Speed w/ '90 built N/A motor and interior
1958 Ford f-100 straight-body (Grandaddies truck, resto-project)
In nashville we have a company that does all our clutch needs to order. They're fantastic. It's like "Tn speed sport" or something like that. Other wise I would swap to the TT stuff and get like a stage two clutch and pressure plate and call SpecialtyZ or Concept and see what they recommend for that. Those would be my options.
