Performance Chip
blakeaustintusn
Car: 92 Lexus ES300, 88 Volvo 760 TI, 87 BMW 325IS, 96 Nissan 240SX SE, 03 Nissan 350Z
What is a good chip to buy for the KA24de? Where can I buy it? I have a 96 240sx se. I dont want to buy some piece of crap off of ebay and I also dont want to spent to much on it since I plan to put a t28 on soon. If anyone has any good ideas please let me know. Thanks for the help.
neverlift
that makes no sense the tunes will not be compatible once you slam the turbo on.Also you get what you pay for when it comes to chips.You could go full standalone for about the same price.
blakeaustintusn
it does make sense. i dont want to spend to much because i know ill just be taking it off when i start to put together the turbo. just wondering what is a good priced chip for the KA motor and where to buy it. maybe its just better not to buy one at all and just wait till i get the turbo parts together. thanks.
corn322
Car: 1993 240sx
If you have access to an EPROM burner, you can make your own fuel & timing maps, among various other things.
Read up on it here:eccs.hybridka.com
neverlift
the reason I say it makes no sense is bc, turbo tune is different than N/A tune. Do like corn said get an eprom burner and change setup when turbo time comes, and have plenty learning time while not boosting.
blakeaustintusn
alright ill check it out guys. thanks alot for the help.
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
The s14 ecus dont have a whole lot of options at this point, but there are some promising endeavors currently in the works.
As far as a basic eprom board, the closest solution would be the GRID multiboard with the R34 connection slighly reconfigured for the S14 ka. There has been talk of a basic eprom board being created specifically for these ecus in the US but nothing yet that I know of.
Bikirom supports these ecus though as well, something to look into although software and upgrade support seems a little limited/slow.
There is a real time editable solution in the works called Erich's Tuner. It is a nissan ecu-specific emulator board that fits into the ecu case like a bikirom, but allows tuning in real time instead of only key-on/engine off updates. The designer is looking to support the early model S14 ka ecus.
