Performance chip for my Q...
hswilliams2525
Car: 2005 Infiniti Q45
Hey Guys, what would be the best performance chip for my 2005 Q45?
Thx
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
The only one is Impul. Good luck getting one.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I'm not convinced chips for any car 96 and newer is worth it. They dont give the gains for the money
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
True, except for factory turbo cars. The naturally aspirated ones are pretty much tuned out to the limit. The chips just thin the safety margin more.
elwesso
2007 BMW M Coupe
Actually I was doing a bit of research an on most newer cars they can't really change the A/F ratio or timing much because as you said they are tuned to the limit. They really just change the throttle by wire to make it "feel" like you have more power. I remember reading about a "tune" that was done on an FX45 and it netted like 10 HP for $800
qship96
Car: 1996 Infiniti Q45
You guys are repeating old outdated misinformation......... http://www.uprev.com plenty of newer Infinitis are packing an extra punch all around you!
elwesso
2007 BMW M Coupe
I searched around and the uprev tunes are showing minimal to no gains on an otherwise stock vehicle. 10 HP for that kind of money is stupid, you would never be able to tell the difference. You certainly aren't gonna be gaining 30-40 HP like you can on pre-96 vehicles. 20 HP is barely noticeable and still you'd be better off savin money.
qship96
there is much more available than the 10 HP you quote from UPREV and others.....keep digging.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The safety margins are so thin, I doubt there is 10% gain by removing all of them, which will lead to engine damage with one tank of below standard gasoline.
To get real gains, you have to change internals like camshafts and pistons then reprogram.
Turbos are another thing.
