szh »
https://forums.nicoclub.com/szh-u149.html
Tue Aug 19, 2008 1:02 pm
The M35 is not much better in terms of gas mileage than an M45. You may see about 1 to 1.5 mpg max difference. Be prepared for low mileage in both cars ... not much better than your current Q45 really. So, please don't go into these cars expecting to improve gas consumption!
Overall performance of the M35 and M45 are similar too. The M45 just does the acceleration a bit more easily, with less of a strained feeling, but the end result is mostly the same - the gain in power and torque of the M45 compared to the M35 is mostly offset by the heavier engine.
OTOH, the maintenance cost of the V-6 is probably lower by a small amount ... fewer plugs, smaller oil capacity, etc., etc., etc.
The interior is pretty much identical, of course!
So, overall comment: they are both excellent cars and you would not go wrong with either.
Having said that, I personally prefer the M45 to the M35 ... only because of the ease with which the power and torque are made available in a V-8 compared to a V-6. My opinion, of course.
Z
