Personally I'd go with a tune from UpRev.blackmamba370z wrote: What about a superchips?
I realize the way I organized my post concerned the Magnusson Moss act is a bit misleading - I wouldn't consider warranty being intact with any type of Forced Induction application unless you went with Stillen installed by a Nissan dealer (my dealer has told me that they would be able to do that and retain my warranty but that's as far as the conversation got).jerryd1987 wrote:Not understanding what your trying to get at xenon that act has no relevence to the conversation, Nissan is 100% able to void there warrenty for fi the judge will rule in there favor ever time, in the eyes of the law such modifications are deemed as abuse. Stillen is also legally allowed to back nissans warrenty if you install there product the way they say. As far as dyno...... Well I already made my comments about that since all those 340 whp dynos are rock 1.1-1.2 air density correction factors which is misleading as s*** and is exactly why those cars are posting 310-315 who quarter mile times. Why I hate dynos for a measurement, I could make my car read 1000 whp on low boost all day, dosnt mean that's what its doing quarter miles times are the true test. Frankly the op won't get close to 400 whp without FI or a huge a** stroker kit which will cost several times more. The boost the nismos get is in better exhaust and intake. The intake manifolds are the same, the headers are the same, and the tune is slightly more aggressive. The 280-290 ish is about right for stock, and 325 is the most any z is going to hope for without spending a ton of cash. So he can spend about 6k for the cost of parts and labor and gain mayby 35-45 whp depending on manufacturing tolerances or he can spend 8-9k for parts and labor and make guaranteed 150 whp gain. Increasing cost by 50% but trippling the gain is a far far better bang for the buck. No he isn't going to make killer power on a stillen blower but that's now what its ment for.
My nomination for "Best No BS" post of the year.jerryd1987 wrote:For the recommendation of the stillen he made mention of a 400 hp goal which at the wheels wontn happen without a stillen. For a 370z to put out 330-340 whp considering standard drivetrain and wheel losses and the fact that most of these dynos make peak power between 7k-7k5 that means its going to need between a 92-96% VE which isn't possible on a street engine with mass produced parts on race gas let alone pump. Even 50k pro mod engines only run about 102% on race gas and custom everything, dry sump, titanium rods, lightweight pistons that sideload easily and Honda bearings. To get that number reasonably your going to have to spin the engine to around 8500 and might still need custom built headers.
Hence why dynos arnt really a good measurement, the 3.7 isn't a vast improvement over the 3.5s it ahas the ability to not need cams since it can change through tuning which no one is really taking advantage of(and useless if you don't update exhuast cams also) other then that it has a little more displacement nothing more. To get the amount of VE needed for that type of power on a legitimate dyno you need to know exactly where the engine is capable of making the power and then custom building cams, intake manifold, headers, and full exhaust to suit that. Your not going to buy off the shelf parts and do it and the power is going to come mostly from rpms.
Shops post up all these dynos and then customers buy into it then get upset when the car dosnt perform like it should for the power it supposedly makes. A perfect example is the sg motorsports 350z. He had a full engine build done, custom built headers, put individual throttle body's on and a very aggressive tune that wouldn't survive long on the street then posted a 372 whp dyno and everyone went nuts and started buying up there headers. Everyone COMPLETELY ignored the fact that he set air density correction to 1.2 and had the computer take in an uncorrected 50 degrees temp. Take those out and the engine was making close to 300-310 whp, real horsepower not what they made the dyno read with over 15k in parts and labor. People ignore stuff like that though
