crackler »
https://forums.nicoclub.com/crackler-u26495.html
Sat Oct 18, 2008 4:59 pm
The other thing you can do, is get some good shocks, and lowering springs, then once you deiced you want a higher spring rate, you can get some ground control, or if you get Koni shocks, they make them as well, lower adjustable spring perches and springs. Then you will have ride height adjustability, and be able to run pretty much any rate spring you want, so long as the shock can take it. More of a stair step, so you don't have to trash your shocks and springs all at once.
The best thing you can do, if you are in fact serious about drifting or what not. Is hit as many schools as you can. Nothing will make you faster than seat time. you throw a crappy driver in a fast car, and if he doesn't loose it altogether, he still won't be fast. You can put a good driver in damn near any car they will be fast (relatively speaking of course). Then once you decide if you are serious, then start adding parts to the car once the loose nut behind the wheel is worked on.
The only thing else I can add, is read as much as you can. get informed on how suspension works, and why. Once you have a decent idea of what is going n with your car from a theory point of view, you will be able to make better, more informed decisions.
