perfect offset for flush look
jhuerto23
Car: 2006 Infiniti M45
I have saved up extra cash to buy aftermarket wheels. I am going to go with XXR 521's in black finish
20x8.5 front
20x10.5 rear
I am on tein H-tech springs. What offset would you guys recommend getting and what size tires? I would also point out that I do not want to do any custom fender or suspension work.
thanks in advance,
jeff
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
I'm no expert in this, but I'll say from jump ALL 10.5 I've seen on this car stick out.
zags
Car: '09 M35s "all black everything"
^ the et measurement "offset" is key.
You can run a 10.5" with a ~ +39 et and 275 30 20's no problem, that is more or less what I am running with the modified OEM GT-R (R35) wheels.
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
not sure about the 10.5 for the rears, but I think 40 and under would work...are the wheels you plan on getting with or without a lip?? or are they the concave style??
you can try this site for wheel choices and compare....they also provide the option of offsets that will fit as well as tires to match...
http://www.elementwheels.com/vehiclesea ... rice=&pg=2
TDot
I'd like to see a pic of that if you have one.
06M4.5
Car: 2006 M45
Flush as in not sticking out, I would do front around 27 and for the rear around 48
Pending on tire size
jhuerto23
I was given Front 30 and the rear 32. Would this work?
06M4.5
Car: 2006 M45
jhuerto23 wrote:I was given Front 30 and the rear 32. Would this work?
Not for the rear
Check my numbers above
jhuerto23
06M4.5 wrote:Flush as in not sticking out, I would do front around 27 and for the rear around 48
What tire size would you go with. I might have to go a diff route.
jhuerto23
CPJ LB wrote:not sure about the 10.5 for the rears, but I think 40 and under would work...are the wheels you plan on getting with or without a lip?? or are they the concave style??
Thanks for the link :dblthumb:
06M4.5
Car: 2006 M45
If you have bad roads most go with front 245/35/20 and rear 285/30/20
Those that go the vip way use front 235/35/20 and rear 245/35/20
jhuerto23
06M4.5 wrote:If you have bad roads most go with front 245/35/20 and rear 285/30/20
Thanks for the reply :dblthumb:
