evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Dec 29, 2006 6:43 pm
the VG30ET is a blt in, it just requires bolting in the crossmember as well, the VG30DETT however requires lots of fab work
I'd suggest the VG30ET, simple, reliable, cheap, lots of potential so you can start with the swap and add I/C later, and then larger injectors and larger turbo till you're happy
