People wondering about CA/SR transmission swappin
S13ChucKAT
Car: asd
Well, I did a little looking.. and i got all the FSMS off the web..
After looking at the CA, and SR bellhousings... the end where it attaches to the gears is exactly identical.. I believe SR and CA trannys will swap at the bellhousing NO problem.. Download the PDF's and search for yourself...
S13ChucKAT
Car: asd
and here is the CAs' bell housing pic
cortina-mk1
Car: GT-R Skyline, MK1 Cortina's
what you have to think of is the spigot size and the input shaft size ..splines etc
S13ChucKAT
Car: asd
hmm.. true.. true.. More research among myself.. Man im bored.
cuzan0
the sr transmission will work only if you use the ca bellshouing i know this is cause thats what i am using
S13ChucKAT
Car: asd
yeah thats what im saying.. the bolt patterns are exact.
CA18Fastback
cuzan0 wrote:the sr transmission will work only if you use the ca bellshouing i know this is cause thats what i am using
yeah, the motor i'm selling has an SR gearbox and CA bellhousing, too.
-Ian
pulsar gtr
Car: NISSAN VEHICLES
NOw, is the gear ratio on the SR the same the as the CA?If it is the same, why the headache of converting the sr into ca transmission?If not, than that makes sense if the SR has a better gear ratio
PULSAR GTR
nab911
Car: 93 Nissan 240SX SE
Ease of availability...
fanta
http://www.nissaninfiniticlub....72059
pulsar gtr
Hum,So, the gear ratio is the same just the fact that availability is an issue.
I gotta spare 5spd CA transmission if any one interested
PULSAR GTR
nab911
Ca transmission w/o housing? :)
pulsar gtr
Yes sir, full CA18det transmission 5spd with bell housing
PULSAR GTR
float_6969
Wait, wait, wait. The SR and CA DO NOT have the same exact same gearing internally,(5th gear is different) and the CA's had different rear end gearing too. http://www.nissansilvia.co.nz/...e.htm
boost_boy
Quote »NOw, is the gear ratio on the SR the same the as the CA?[/quote] That's a good question! On the FWD SRs, they use the smaller spline while the CA uses the bigger maxima, stanza, 300zx spline. Gearing-wise, the FWD CA gearboxes have a linger final drive than the the SRs. The RWD SRs seem to have shorter gears the RWD CA vehicles. My friend who has the 509whp KA also feels the CA has longer gears than the KA; but definitely longer than the SR. If you want shorter gears, then I guess it would be wise to do the SR swap. But I say this, make the power to power through the gears and get a better top end less the engine stress.
Dee
pulsar gtr
SR20det gear ratio of an s14,S15, CA fsm S15(RWD) S14(RWD) CA(RWD) 1st 3.626 3.321 3.321 2nd 2.200 1.902 1.902 3rd 1.541 1.308 1.308 4th 1.213 1.000 1.000 5th 1.000 0.838 0.838 6th 0.767reverse 3.437 3.382 3.382
I HOPE THAT ANSWERS YOUR QUESTIONS
PULSAR GTRRafi
pulsar gtr
I tried to put some space in between but some how it kept showing it like above.dam
PULSAR GTR
Import_Ant
It's still very much readable. Thanks for the info!
:ylsuper
-Aaron
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
hey pulsar, i may have to check with you about that sometime in the future, my transmission grinds in 3rd when you shift into it in the low-mid rpm range. hope it isnt going but if it is, oh well. maybe i can rebuild it with custom gear ratios and/or convert it to a dog box.
- tim
pulsar gtr
Well, I am glade that you guys find this info usefull, and r34 gtr, let me know if you need a transmission, you can catch me on msn at [email protected]
PULSAR GTRRafi
