Houmack »
https://forums.nicoclub.com/houmack-u38463.html
Fri Nov 10, 2006 3:04 am
Okay, I'm sure this topic has been beaten to death, but everytime I search for solutions, I get assumptions and people that have heard things that may work.I have an SSAC Topmount manifold and a Hot Shot topmount manifold as well as a T3/T04E 60 trim turbo.
I can't mount weither either manifolds because I can't clear the Brake Booster.
I have a 5spd Manual W/ ABS. This is the "bigger" of the two versions.
Now, I don't want people saying "i've heard you can run a non ABS 5Spd one and it will work."
I'm hoping someone has actually installed a topmount with our without modifications to the Brake system. If you have no touched your BMC and Brake Booster, what Manifold did you use?
If you have modified your MBC or Brake booster, what did you do exactly and what manifold are you using?
What are my options? I don't want to spend $800+ to get a full race manifold and such.
Thanks in advance
