People that run at the track...
Drew2G2
Car: My friend has a 240, does that count?
For the people that run at the track, what are your times? and what is your car w/ what motor and upgrades? any larger turbos? are you on nittos or a sticky tire? just trying to get an idea. thanks
BuudWeizErr
On my run, I had 205/55ZR16 Kumho Supra 712's... @ 48psi (:D). My time and info is in my sig.
float_6969
.5 Bar doesn't equal 48psi......
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
KS_Honda_Killer wrote:.5 Bar doesn't equal 48psi......
tires...?
-Dan:pface
mike_do
i think it was a joke, hence the smiley face
Drew2G2
Thanks for the info, does anyone else run at the track?
BuudWeizErr
:rolleyes
Please read my post again... I never said anything about boost in my post. Think before posting plz.
mike_do wrote:i think it was a joke, hence the smiley face
Please read above.
:rolleyes
the_invisible
It doesn't take much thinking to guess what the pressure was for! He actually stated the PSI in a sentence that is related to tires.
LOL! Classics!
GraySilvia
Car: auto-x, drag racing, beer
48 psi is hella high for tire pressure.....could it be oil pressure? (Seems kinda low for that!)
GraySilvia
I used to run low 13's on my setup, but since i've got all the new parts on my car, it's slower...definately in need of tuning...
the_invisible
GraySilvia wrote:48 psi is hella high for tire pressure.....could it be oil pressure? (Seems kinda low for that!)
dude, your gonna piss Budd again!!!
I H8 UR DSM
I run Nitto 555R drag radials on lightweight 16" rims.225/50 16's to match height of the front rims i run 17" w/ 215/40 17's...
I run more boost than tire pressure ; ) about 14-16psi in the rear tires (trial and error)...
tires are too skinny, but no option due to rim size...definitly recommend a wider tire/rim.
Definitly recommend trailer or spare axles
JESSERPI
I H8 UR DSM
Oh, i would of skipped right over drag radials and straight to slicks, but i wanted to run the street tire class last year, otherwise, i'd recommend full slicks, and some nice skinny 3 piece bogarts with some BF's in the front : )
JESSERPI
Drew2G2
Jesse, what are your times?
I H8 UR DSM
12.8@109 stock motor, stock ecu, stock turbo, Open diff. drag radials.
consistantly between 13.0-13.4 with 1.9-2.1 60ft's.
no traction.
martin
I run about a 1min 32 at Mosport, a 1min 12 on the pro track at Shannonville, low 21 sec laps at Ottodrome....
Oh you mean Drag Race Tracks! I don't do that, I like turning corners!
-Martin.
nismojason
I H8 UR DSM wrote:12.8@109 stock motor, stock ecu, stock turbo, Open diff. drag radials.
no traction.
what boost were you running, and a fmic?
BuudWeizErr
I know it is. I bought tires on a Monday, didn't check the pressure, drove to Vegas that Friday, and raced there, never checking my tire pressure. I have them at about 20 when I'm racing now. 48 psi is above the max for those tires anyways, I don't know why they put that much air in my tires when I bought them. 44 is the max.
godspeed
well if they put it up to 44psi and then you drove around and after that checked your psi, then it can jump up to 48 air expands when it gets hotter
turboex
Hey jesse what are your times and trap in th 8th? thanks man. oh and what boost?
240SXer
Car: 1995 240sx SE (2jz powered)
I just ran at the track, my best time was [email protected]. I only got about a .1 from my exhaust I guess. But it might have been because it was cold as **** and I could hardly hook up. Out on the street I've been dropping it at 4k but that day at the track I couldnt even drop it at 3k. I have Kumo 712s too. It seemed like it lost more traction when I lowered the pressure. I went from 44 to 35 and was still spinng like crazy, so I went to 25 and it still spun just as bad or worse. It also could be because It was getting colder.. Go figure.. Anyway, what's the average gain realized with an Injen CAI?
David.
godspeed
240sxer tell me you don't have a sr
240SXer
No way. KA w/ exhaust. That would be pathetic with an SR.
