pending code, not erasing.
driftneil
Car: A pile of cars.
I had cleared the codes on my 97 nissan 240, stock ka. The code is for the egr vent circuit, and is the only one still pending. The thing that has me wondering, is its been 150 miles since the code was cleared and pending and still no CEL. Why is it taking so long to clear? Any help would be great.....I need to drive this car!! Prethanks, Nico
nismoracingsx
Car: 1993 White 240sx Coupe
it might not be fulfilling all the criteria to set off the light..sometimes a pending code will stay in the computer if your emissions system is only partially failing a certain test or parameter (ie: its only setting the code every other start, or it only happens once every 50 miles..). if its not setting the light, and your mileage is fine, i wouldn't worry about it on such an old car.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
not being a d!ck, but i dont want to take the time to draw this out for you. takes to long to write about trips and enabling criteria. WAY TOO LONG.but, i can see you need help and it is kinda a tuffy so, ill help you out.http://www.aa1car.com/obd2help/thats, in a nutshell/condensed version the info you need. will also give you a better understanding about obd2 and why/when/why not things set.hope this helps
driftneil
Wc240 wrote:not being a d!ck, but i dont want to take the time to draw this out for you. takes to long to write about trips and enabling criteria. WAY TOO LONG.but, i can see you need help and it is kinda a tuffy so, ill help you out.http://www.aa1car.com/obd2help/thats, in a nutshell/condensed version the info you need. will also give you a better understanding about obd2 and why/when/why not things set.hope this helps
Thank you very much....That helps alot. Im wondering if my car has a "not ready" issue? And just will not reset.
