Pedal Swap question?
92vert240
Car: S13 hatch S14SR20 stock record-12.35 at 110, 87 t-type 10.69 at 132. hatch daily.
Will the pedals from a right hand drive s14 mount up in a s13 left hand drive car? I have a RHD clip and a s13 w/ no pedals. If not i'll be looking to trade or sell the pedals for s13 LHD stuff. Thanks.
CMG
Car: 1989 240sx Hatch w/ Redtop
I used an S13 RHD gas pedal in mycar, but I don't know if it's the same as S14. The S13 RHD is better than US S13 pedal as it has better angle and spring.
Hijacker
Car: '92 240sx Convertible
'94 F-150
The S14 pedals aren't a direct bolt on to an S13. The S13 firewall has castings and what not that the S14 lacks. The pedal brackets were designed with that in mind. I've successfully put an S13 clutch pedal into an S14 (required spacers on the pedal bracket studs), but I don't think you can do it vice versa.
As for the brake and gas pedals, I'm not certain. I want to say no, but the only experience I have is trying to put an S15 gas pedal in an S13. It didn't work out.
