pedal sticks
spider_slayer
Car: S14 240SX
S13 240SX
well, when ever i press on the gass pedal nothing happens till i press it about an inch down then its fine and will work correctly again. its really annoying, anyone have any ideas how to fix this?
Florida240sx
You talking about like in the morning when you get in you got to apply more than usual force to get it to go down?
Thrwnsprkz
Car: 240sx
i replaced my clutch w/ a 6-puck and ever since my pedal will stick closer to the floor seeming like its all the way in, but you can still depress it and use it like normalmy mechanic said its nothing to worry about, you can pull it out to normal distance w/ your hand or foot if you want but then it sticks in again
Dirtylou
Car: 1991 Nissan 240SX RMS13
Wierd...my S13 does that too. Like you have to push on it harder to pop it or something. It goes away after that intial pop until the next day. I haven't really gotten around to look at it though.
Axel Grungy
Car: 2001 G20 5spd
check to make sure your throttle cable isnt binding. if so, use some powdered graphite to lube it
Nismo240s
Car: 92 240sx SE, 96 Maxima GLE, 05 Titan SE
Try cleaning your throttle plate, thats what it sounds like to me. Butterfly sticks do to the carbon...
Axel Grungy
Car: 2001 G20 5spd
yeah good suggestion i forgot about that. just shoot some carb or brake cleaner in there
Dirtylou
Yeah...that sounds like what it could be. I'm surprised I didn't think of that. Throttle cleaner rules.
