ca18datsun510 »
https://forums.nicoclub.com/ca18datsun510-u939.html
Thu Jan 11, 2007 11:54 am
you may have to adjust the pedal free play also. did you notice the nut on the rod sticking out of the back of the master? there is an adjustment for the pedal.
as far as bleeding, fill the reservoir, have someone inside the car pump the pedal about 5 times, and hold it on the last pump. go under the car, it helps if you have a glass bottle and a rubber hose that fits on the bleeder. put a little fluid in the bottle, put one end of the hose on the bleeder, put the other end in the bottle. as your friend/mother/gay roomate/ whatever holds the pedal, open the bleeder. watch the air bubles. close the bleeder,
repeat, pump, hold, open, watch air bubbles, close, repeat, till you see no more bubbles.
