Well I noticed that i was getting some clunk when braking going slow and when turning around in a parking lot or something. While i was under my car a little while ago i noticed that both of the tension control rod bushing were all broken apart and leaking the clear viscous liquid. I came across these at PDM Racing:
http://www.pdm-racing.com/products/suspensiontc.html
I ordered these and they are on their way. I'm hoping this will fix some of the problems i'm seeing. Here is a quote from that page:
Quote »One of the most troublesome bushings on the 240SX and 300ZX, this silicone filled "donut-shaped" bushing which is pressed into the Tension Control rod, is one of the first bushings that wears out. When it fails, the viscous filling will leak out, and corrode your front suspension's paint finish, and will cause erratic steering (especially at highway speeds). The front end will also make a "clunk" noise when you make tight turns. Fix the problem with these Whiteline replacement bushings.[/quote]
Take your undercover off and look at these rod bushings to see if they're falling apart... hope that helps.
