I just got a used 2010 Armada Platinum and the pedal adjustment feature does not seem to work. The gas pedal runs in and out just fine but the brake does not move.
I'm not doing well attempting to navigate this forum so this may be a redundant question and maybe someone can direct me to the answer.
FALSE ALARM - I got under the dash and after inspecting the gas pedal operation poked around and found that the drive cable for the brake pedal was disconnected. I alternately connected and disconnected the cable until I could get both pedals fully to the same stop and then reconnected the brake drive cable and snapped it into place. I could not see how either cable was actually attached to their respective pedal assembly but when I pushed it on it felt secure.
The FSM implied there was only one motor for the pedals but there seems to be a separate one for each pedal. For the gas pedal, it is mounted right on the pedal assembly bracket. I could not see the brake motor but the drive cable was long and wrapped over to the side of footwell and dissappeared into the darkness near the top of the dash area.
