[S14] Peak Performance Rear Toe Doesn't Fit???
pat93
Guys, I'm doom.I was with my mechanic to install coilover/ruca/rear toe on my s14zenki.RUCA is fine, but rear toe plays because the spacer is short.I have attached the picture comparing to the stock.
It isn't snug into the subframe.... it really plays from left to right
measure stock one
Measure peak performance
Obviously, stock is wider than peak's
Any peak performance users have the same problem or your rear toe perfectly fit?Please suggest, thanks
adrianfromthecastle
Car: 1992 Nissan 240sx
wow.. I've never seen or heard of that problem...
you sure its the s14 and not s13 rear toe you have (if that even makes a difference).
