I am a noob especially about engine rebuild. My goal is to pass emissions and retain the low end torque BUT also want top end power. Also, I don't want my ECU re-programmed. It seems like pdm-racing camshaft is what I need. Could someone please interpret or explain what I get from the two cams?
Other related questions:1) If I get the pdm-racing, can I still use the JWT adjustable cam sprocket? Or is it specifically designed for JWT cams? What is the advantage and use of having an adjustable sprocket?2) Colt makes the pdm-racing camshafts. Who makes the JWT?
Here are the info for each individual camshafts:PDM-RACING:C.702.S Stage II Cams - Intake 221 duration @.050” .379 lift; (272 advertised duration), .380 lift; Exhaust 231 duration @ .050" lift, (278 advertised duration), .390 lift.These cams are VERY streetable, with no injector or computer upgrades required, and pass the strictest emissions with proper tuning.*This is the link to the dyno with intake, pully, header, and tuning):
http://www.pdm-racing.com/products/DOHC ... .htmlPrice - $585 / set
JWT: S1 CAM SET 91-02 KA24DE (RWD ONLY) .390" LIFT / 275 DEG. DUR. GOOD IDLE EXCELLENT MID- RANGE TORQUE. GOOD ALL AROUND SPORT CAM. USE JWT ADJUSTABLE SPROCKETS #AKADE-SPROC FOR TURBO OR TOP END POWER.Additional info I got through email from JWT rep:Makes about 10 more HP and is designed to be used with the factory valve springs and retainers. Lift is .390" duration is 275 degrees.Thank you in advance!--Leon
