Ajax »
https://forums.nicoclub.com/ajax-u5731.html
Thu Apr 07, 2005 7:11 am
Please allow me to clarify as I may not have typed exactly what my brain was thinking.
It sounds to me like 240sxHitman is not quite sure when the engine will be turboed. If this is the case, I would hold off on getting internals for the engine until there is a clearer idea of what is going to be done. I recommend not buying parts that may not be of use to you later (i.e. I bought some Whiteline bushings for control arms, that if I had waited until I knew more clearly what I was going to do with the suspension, I probably would have bought the bearing links instead).What if 2 years from now, when you have enough money to go turbo, you decide to go sr20. Well, then you've got these nice cams for a ka that are of little use and will not sell for as much money as was paid. (If you've got money out the wazoo, then by all means, go ahead.)My opinion is based mainly on economic efficiency. Sorry for any confusion that my hasty post may have caused.
