RedShred »
https://forums.nicoclub.com/redshred-u5562.html
Thu Jun 12, 2003 6:41 am
C404.H - Strong performer, with good midrange pull to redline. O.K. with automatics. Our strongest seller with the most smiles! {Intake 268 degrees duration, .441 valve list, Exhaust 272 degrees duration, .447 valve lift.} (note requires cam towers to be milled .030")
I'm using one that is very similiar to this with only the lift being like 450 or alittle more, I cannot remember...
I have a horrible idle as it is rather lumpy, but I have nearly 10:1 compression and port/polishing to go with it. My Ports were opened alittle more so it is breathing more. Other than that I dont have any stalling issues. My Car comes alive after 4000 rpm though... not real good for the street but fun anyway.
As for the Cam Index gear... Nismoparts.com has one. I have one but havent installed it yet. I figure I'm 2-3 degrees out and timed slightly retarded and it runs well there. *shrug* I'll eventually install the degree'ing gear but am not in a hurry.
