centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Thu Mar 09, 2017 1:37 pm
According to GM Research Laboratory, about half of the cars hydrocarbons come out of that valve. That is, half of all of them, before having a cat or Evap or any other emissions device added. So, half of everything if your car ran in it's dirtiest state, no emissions equipment. The PCV was one of the first emissions cleaning devices. You want to route that stuff into your intake, which is what your OEM system does. If you cap the vacuum, then you only have the pressure of the crankcase to open the valve. I'm not sure, but figure it would be harder for it to open if not assisted by some vacuum. You may be reducing the lifespan of your oil. It sounds like you want to vent your PCV to atmosphere and have a small oil catch on the end of that and you leave alone the breather hose. Is that right? I think you are merely gaining more SMOG for your environment. No power, no cleaner intake, no improvements, just more pollution... I think. Why do you have this idea? (simple honest question, no implication or inference)
