Thank you for the kind words
I'm not sure I can accept donations, and I doubt they're warranted in the first place. I'm glad to help.
One thing I forgot to mention, the
threadlocker on power valve screws guide will help you get to the PCV valve if you aren't familiar with the process yet. Put threadlocker (preferably red) on the power valve screws if you haven't yet, of course. And be sure to disconnect the PCV hose before you lift off the lower intake manifold, otherwise you'll crack the PCV valve in half just like I did.
It may also be prudent to install a PCV catch can to condense and collect oil vapors from the blow-by coming out of the PCV valve so there is less oil potentially pooling in the intake manifold and coating the throttle body plate - see
Pwnin O'Brien's setup here. The only downside is needing to empty the can every other week or so. Technically, this can be added any time, it's just a lot easier with the intake manifolds off since the PCV hoses are so buried when everything is assembled.
Be sure to get an OEM PCV valve only. I wouldn't chance saving $6 buying an aftermarket part when the valve is so difficult to access.
