TEK112 wrote:The PCV valve is located on the right side of the throttle body(ECCS) , you may have to unbolt the throttle cable assembly to reach the the valve. Your best bet is to get the part ahead of time so you know what you are looking for. The PCV valve will look like a nut coming out of a hose connected directly to the right side of the throttle body.
