First I lifted the car on jacks. Then remove the alternator. I also removed the air hose connection to the air box.
Once the car is lifted and the alternator removed, its just a matter of getting that pcv valve off. It's a tight fit but
it can be done.
#1 -
#2 -
In photo #2 the empty spot to the right of the Oil Filter is where the Alternator was but I removed it.
#3 -
photo #3 is the view from under the car. All labels in the photo should lead you accordingly.
#4 -
#5 -
Photos 4 and 5 are just closer images that should lead you better.
reply with questions if you have any. PS--- This is my first post, so if its in the wrong place or anything uhhhh... sorry.
