vancouverbc »
https://forums.nicoclub.com/vancouverbc-u10923.html
Sat Apr 21, 2007 6:44 am
from faq:
On the SOHC the PCV valve could not be in a more accessible spot! It's at the side of the intake collector, which is the thing with ECCS imprinted on it. Took 5 mins to replace and most of the time was spent pouring water to loosen the hose.
Shawn you may want to make a note that A&W's faq is for DOHC only. They also specify that the deep socket needed is 14mm but for the SOHC it's 19mm. There's no room for the socket so it's useless anyway.. an adjustable wrench was the only tool needed and a person with strong fingers wouldn't even need that!
The valve turned out to be in fine condition and did not really need to be replaced.. oh well. Mine only had 75k on it though because I think it came with the engine I bought used.
now I need a "Powered by Fram" sticker!
