acattackgs »
https://forums.nicoclub.com/acattackgs-u28439.html
Tue Aug 12, 2008 2:35 pm
i just had a similar issue with my black top, kept filling catch can and so much poss pressure that my dipstick would raise about 1-2" and get oil all over my engine bay, ended up being caused by bad compression. did a comp test had bad compression. tore it a part last week sure enough major pitting on head, and pistions due to detonation. Sucked but got a new sr and swapped it in. So what im getting at is check compression. You can also pull the pcv on valve cover and make sure you can only blow through it one way. If you can blow both ways you know its bad.
