PCV replacement - 2005 Altima with 2.4 motor
ricklea1953
Car: 2007 altima 2.5 sl and 1995 altima 2.4
I got the model year wrong. Should have been 1995. Please see my other post on this matter.
Can anybody recommend an easy way to get to the valve? My local dealer never replaces them since they are so hard to get to. I have blowby near the distributor and suspect the pcv may be part of the problem.
Thanks,Rick
Modified by ricklea1953 at 4:48 PM 12/16/2007
2008CodeRedCoupe
Car: 2008 Nissan Altima Coupe 3.5SE 6 M/T "Code Red"
i want to know where you found a 2005 Altima, with a 2.4L motor. second off i want to know where you found a 2005 Altima that has a distributor, these cars use distributor-less ignition systems, or "coil on plug" ignition, so gather some more info and see where the confusion is.
OldmanPurdy
Car: 2002 Nissan Altima SE 3.5
I'm looking at the 2002 fsm for the "2.5" litre engine which should be more or less the same as your year and the pcv valve is on the side of the valve cover closest to the firewall. Looking at this diagram it looks like a 20min job at most.........prehaps your dealer thought you had the 3.5 which is a signicantly longer job to do?
