PCV help
tungaz
I'm working on the pcv valve on the drivers side, the other side of the hose is connected to a metal elbow and while i was pulling the hose out the elbow just popped out, its not threaded, is it really just held in with the pressure from the hose or should there be something else there holding it in? also theres no o ring, does it need a gasket of some sort? thanks
RubyRed300ZX
Car: 1993 300zx Convertible
Should be a spring-type hose clamp that "holds it on." They don't really hold anything all that snug. Easy to yank off. Clamp is probably still on the other end.
ThisIsSparTTa
Car: 91 300ZX TT 2+0
It's fine. I freaked out the first time mine popped out. You can actually use that to your advantage in some situations. Just pop it back in when you're ready.
