Gabes13 »
https://forums.nicoclub.com/gabes13-u92491.html
Tue Sep 07, 2010 1:48 pm
The adjustable spacers do look pretty cool, but I don't have them. I do, however, have some generic bolt on spacers; 25mm to be exact. My first thoughts after install, "Why the hell is my steering wheel so wobbly?!" Pulled over and torqued the lug nuts down again. Did that about four or five times driving down the road, still had some wobble. I didn't get it b/c the spacers I had were hub centric. I tried one more thing, hubcentric rings for my wheels. These fixed my ride and steering issues. I recently but on energy suspension rack bushings and that tightened up my steering aswell. Anyways, get them if you want, but I personally don't like them.
tips:
1. Make sure you put some lock tight on the studs that actually bolt the spacer on to the hub. There have been a couple of times that I was working on my car and noticed the nuts were finger loose. I check (and re-torque if necessary) them everytime I take my wheels off.
2. Just like any other wheel stud, the studs will stretch, hence the wobbly wheels I had at first. Torque and re-torque and re-re-torque until they're stretched and tightened all the way. Be careful/ prepared though, I broke about 8 studs during this process. Get familiar with your 3lbs hammer.
3. Spring for the hubcentric ones. I think parts shop max spacers come with rings for free, so that's good. If you have wheels that are not hubcentic, you may experience some steering wheel wobbles. Grab a set of wheel hub rings and you should be set. They usually go for about 10-40 dollars depending where you purchase from, sizes, and the material they're made from.
They're holding up so far. I dont track my car very often, but I've hit a couple of curbs and done some dirt drops and my wheels haven't fallen off yet. I'm on the market for new wheels now that wouldn't require spacers though. Purchase them if you want, but proceed with caution. Some extra things you may need to budget in are some wheel hub rings and extra studs.
