PB blaster ran out of compressed air.
xagna
My pb blaster can ran out of compressed air. This is second can in a row. The cans are at least half full but no more pb blaster comes out because there's no compressed air. Is there any way I could you this half full can?
180fan
Car: 89 fastback
probably squirting it at odd angles will empty out the air before the fluid.
xagna
Thanks for the tip.Even when I press the shoot out button while holding the can upside down, nothing comes out nor makes noise. Doesn't this mean that all air has gone?
Set the can in a pan of hot (not boiling ) water.
If this doesn't help, buy a new can.
Valley
Car: 00 celica gt-s 89 240sx hatch
punch a hole in the can, drain fluid into misting/spray bottle with adjustable tip, use as needed.
babowc
Car: 240sx
Valley wrote:punch a hole in the can, drain fluid into misting/spray bottle with adjustable tip, use as needed.
i thought thats ^ dangerous to do?even with not too much compressed air in the can.. i wouldnt recommend doing it.just buy a new can, its only a few bucks..or take it back?
Valley
no, i have used this trick when the compressed air ran out in cans containning sprayable gun cleaner (great on barrel's to losen grime). once the can can no longer drip (held right side up) there is no more pressure.
Modified by Valley at 1:11 AM 4/25/2006
Modified by Valley at 1:12 AM 4/25/2006
babowc
Car: 240sx
i see
