Def wrote:I assume you've read some books on gettnig your car setup. You'll want to work on things like tire stagger, camber and getting rid of oversteer(which is bad bad on an oval).
I'd definitely call around to a few manufacturers and tell them what you're doing, offer to run a sticker on your car just for helping you out with custom rates made in a stock spring size. As far as brake bias, can you not upgrade your rears? What about using a slightly more aggressive pad out back as a crude way of changing the bias? Have you looked into any other stock proportioning valves that would fit from other Nissans?
Thanks for your response "Def"... It's sometimes difficult to know where to start when bringing up a new subject on the Forums. Too much detail and it doesn'rt get read...
I've been racing for a while. I have two championships under my belt, and one I missed by 3 points. I run ~ 2" rear stagger, 1/2" front. 7.5 degrees -ve RF, 2.5 -ve RR, 3 +ve LF, 2.5 +ve LR. The car is regularly scaled, 52% front, 55% left, cross weight can be anywhere from 49 - 53% depending on how I shim.
Oversteer is nowhere near as bad as understeer, at least not in my opinion. Understeer is my big problem right now, caused by the front brakes locking up (because they made me remove my bias valve).
I'm looking for any OEM bias valve that I can use to reduce the front brake pressure. Adjustable would be perfect, non adjustable would be worth a try. It just can't be adjustable while I'm driving, or a racing one (which is what they made me take out). I'd love to be able rto put teh racing one back in under teh hood, but that won't fly!
The springs and shocks/struts... I'm anticipating a problem here in the near future. I know this is the next thing the tech inspectors are going to pick on me about so I was trying to come up with a solution in advance. Calling the manufacturers is a good idea. Once I figure out what spring rates I need I'll do that. So far my spring rates have been basically guesswork. This is something that isn't covered very well in any book that I've read. The mini-stock books only cover the mustang/pinto which have twin A arms front and solid rear axel. The road race books say something along the lines of "springs are a personal choice, I recommend enough spring to keep the car from dragging on the track and to keep the suspension from bottoming out" which doesn't really give me much to go on :-)
To stock struts are the limiting factor here, trying to find a non-adjustable stock shock that can deal with high spring rates is tough which is why I was thinking of building some using inserts from a much haevier car. Currently I'm using Tokico Blues which I've tried with spring rates from stock up to 800lbs.. with 800lbs the car was low and handled like a go-kart, but bounced like a son-of-a-***** on the bumps around 400-450 seesm to be tha max these car take without bouncing too bad.
Hopefully that is enough background, and detail to give you guys something to work with . That's way more secrets that I'll usually dissclose in a public forum ;-) My competition might be lurking...
Thanks for any help... Martin.
