Hey Dee, looks good. I cant wait to see that thing on the road. You can easily do 600+ on your setup, but too bad its not RWD!
I havent heard from you in a while man. Hope the built comes out flawless.
I have a quick detailed question for ya......
I just finished tesing my car, and the Leakdown test turned out great. We put 95 psi into the cyl, and ~100 psi held steady in all 4 cyl. Compression test is also good, but spark plug #3 is all cooked up with oil/soot. Would a bad valve seal leak that much oil through to build up alot? Driving home, boosting 1.1 bar was fine, it was when i finished 2, 3rd gear I let off to slow down and when i revved it to rpm match downshift, i see a bunch of smoke. The car doesnt smoke when i startup, unless I free rev it and its cold outside.
What would you think?
Ray
