Pathfinder won't shift past 2nd or into reverse
Brute 03
Car: 2003 Nissan Pathfinder
2003 Ford Mustang GT
Hey guys, I have a 2003 Path with ~75000 miles. Problem is the trans won't shift past 2nd gear or into reverse, but this only happens when the truck is cold. This is a major PITA since I always have to park facing OUT or risk getting stuck until it warms up enough to engage reverse. Has any one heard of this issue? I checked the fluid and the level is ok and it smells normal.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
When was the fluid last changed?
Brute 03
I'm not sure but it worked fine when i bought it at 62K miles. Should i change the fluid and hope for the best?
Towncivilian
Yes, try a drain & fill with Valvoline MaxLife ATF. A drain & fill takes about 4 quarts (one gallon).
Brute 03
Ok I'll work on that along with with the leaking oil cooler :gapteeth:
