pathfinder will not start
Discuss topics related to the VG and VE series engines.
srw45
Car: 1989 pathfinder
Not sure what happened, driving along , it started running rough and then it just stoped. It will crank over but no fire. Checked for codes were two . # one was 11 and the second was 21 . This thing has a 3.0 in it with about 150 k on it . bent values repaired , new water pump and timeing belt about 2000 ago. was running great until this happened, Steve
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
what is the code? I can probably help you. But you got to tell me what a code 11 and a code 21 signifies. I take it that it is an OBD-I vehicle (pre 96).
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Wow...I need to look in here more.
Well, if you're still hoping for an answer 10 days later:
For the Maxima with the same engine, code 11 is the Camshaft Position Sensor and code 21 is "Ignition signal in the primary circuit is not being entered to the ECU during cranking or tuning." I'm not sure if the codes are universal between the Maxima and Pathy, though. Assuming they are universal, I'd check your distributor.
Return to “VG30 / VE30 Forum”
