Pathfinder turbo???
alhamili
Car: 2005 INFINITI G35 COUPE
Hi I own a 2003 pathfinder VQ35DE 5 speed manual and i want a turbo charger will i find a turbo kit or if i can make a custom kit what size injectors i will need and what size turbo and what kind I don`t want to go high boost max will be 8psi thank you....
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
I have nothing to offer in the way of turbo advice, but just want to say welcome to NICO and I love your Pathfinder!!
By chance, have you dropped a turbo on your G35?
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
ive seen turbo headers for the 3.3l on nopi.com only problem is they are like 735 dollars.
KoukiS14
pathfinder_se_black wrote:ive seen turbo headers for the 3.3l on nopi.com only problem is they are like 735 dollars.
I think they need one for a VQ. . so that wouldn't work. . but I'm interested. I scoured NOPI and couldn't find it tho.
Axelpkt
Car: 2002 Nissan Pathfinder 5spd
Can always just get one for the 350z and try and make it work/fit. Thats what i plan on doing for headers eventually.
alhamili
KoukiS14 wrote:I have nothing to offer in the way of turbo advice, but just want to say welcome to NICO and I love your Pathfinder!!
am getting a single turbo kit for the G35 its on the way....
Axelpkt wrote:Can always just get one for the 350z and try and make it work/fit. Thats what i plan on doing for headers eventually.
i dont want to spend more than $5000 on a 350z turbo kit and dont fit....
KoukiS14
alhamili wrote:am getting a single turbo kit for the G35 its on the way....
NICE!
rubiconxj
Car: 2001 QX4, 1980 280ZX 10th Anniversary
If you could find/fabricate a turbo setup, how would you get more fuel? Are there programmers available for the 3.5?
My suggestion would be to make an "STS" knock off kit. That way you have unlimited room for the turbo, because there might not be enough room under the hood and headers would be expensive and almost impossible to fabricate.
alhamili
rubiconxj wrote:If you could find/fabricate a turbo setup, how would you get more fuel? Are there programmers available for the 3.5?
Hi i will try to make a custom single turbo like the APS single turbo that they offer for the 350Z and G35 but it will take sometime and the UNICHIP will fit.
Midwest_Drift_Shop
Car: 85 300ZX Slicktop, 85 Maxima Wagon Turbo, 87 200SX, 93 Infiniti J30, 01 Pathfinder 3.5L
Adding a turbo to an R50 would be a pain.
You will need:
Custom Turbo manifolds to fit the pathfinder, I doubt the 350Z ones would fit.
Low Comp pistons, if your planning to run more than 6-7 PSI, 10.5:1 is kinda high to run more than 7-8 psi.
Larger Injectors, depending on the wanted boost.
Intake piping and/or intercooler.
Blow off valve.
Tuned ECU for larger injectors.
This can be done, you'd be looking at $2500 to $3500.
It would be fun, the R50 drives more like a car than most other larger SUV's, and the VQ35DE is an incredible engine...
rubiconxj
I am becoming more and more interested in the possibility.
I am not familiar with these motors but am well versed in the Turbo Buick world. There are alot of injectors out there. I just don't know if they would be similar to Buick injectors or not.
I think the piping might be a nightmare, especially if you want something mandrel bent. You could weld a series of pipes together. Mandrel bent angle pieces can be ordered. As suggested before I wouldn't even try using the Z headers. Replace the muffler with the turbo and plumb everthing from there to the motor. It has worked very successfully on Toyotas, LS1s and the like.
I think an intercooler is a must, because of the high compression. Alky injection would also be a big plus to keep te intake charge temps done.
Blow off valve, only if you have a manual transmission.
Tuned ECU for larger injectors (This is my biggest hurdle.) I don't know what tuning is available for these ECMS. Someone mentioned the UNICHIP but I don't know if that's a laptop software tuning program of what. I wouldn't feel comfortable adjusting fuel curves, timing etc. on my own.
If someone is seriously thinking about doing this I would love to see it done. I don't have the funds to attempt it right now and my Q is my daily driver.
NNothing would be cooler than smoking all four tires in 4wd
tmorgan4
Car: 2000 Nissan Pathfinder
For anyone looking at a turbo/SC setup for the 3.3L a company has just come out with kits that are supposed to fit ours. The website doesn't have a ton of information, but the company is called Alpine Developments.
