yuellig wrote:I have a 07 Pathfinder with the factory 4 pin tow package. I think it is hardwired for a 7 pin round RV plug . The 4 pin flat plugs into a harness on the left side of the frame near the tire. There is also an other plug there also. Is this extra plug for the 7 pin? Is this also hardwired for a brake control? In the fuse box in the engine compartment there are fuses in place for brakes. Are these also for the tow package? What will it take to convert the 4 pin flat to a 7 pin round? The dealers don't know and just want me to "bring it on in"Bob the caver
I wanted to mention a couple of other things.1) I seriously doubt that a Pathfinder (or any other SUV) comes with brake controls from the factory. To my knowledge, the only passenger vehicle that does is Ford's HD F250/F350 truck. Even if it the wires are already there, you will still need a brake controller to be installed somewhere in the cab.2) Your owner's manual should indicate if the second plug you see is for additional towing wiring. On my truck, the manual pointed out a wiring harness that was tied up with zip ties that I probably never would have found.3) "Taking it in" isn't such a bad idea. Wiring up vehicles isn't the most difficult thing, but there are risks and it's time consuming. Some things are worth paying an RV shop $250 (including the cost of a brake controller) to do it for you in a day.
Speaking from a lot of experience towing and hauling heavy things, don't be cheap and skip things that you need. Since you are asking about electric brakes, I assume you are not towing a boat. If you are towing a heavy load, get weight distribution, sway control, and brake control. You don't want to be driving down the highway with no weight on your front wheels and smoldering brakes.
