Pathfinder timing belt replacement??? and knock sensor replacement on 2000
yamarider189
Car: 2000 Nissan Pathfinder
I have recently purchased a 2000 pathfinder and was wondering what I needed and all had to do to replace timing belt??? Any info or pics from some one that has already done it would be great. Also is there anything else I should just do while its all apart???
Also same for the knock senors all what do I need to do and if anyone can tell me that would be great .... thanks so much , Zach
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
How many miles on it?To your knowledge, has the belt ever been changed?I have the 3.5 so I don't have to worry about it, but everything I've read here seems to point to a 100,000 mile threshold for the belt, if I'm not mistaken.
alexf20c
Car: '00 SE 4x4
why are you replacing the knock sensor? is it faulty?
timing belt is not exactly difficult, but it's not something you want to f*** up. i'd recommend taking it to a shop, and have them replace the water pump while they're at it.
yamarider189
It has 132,000 Miles on it and I only do know That altenator and the front belts were replaced but never thought about asking about timing belt.
yamarider189
Yes, The knock sensor is bad along with o2 sensor bank 2 sensor 2... I figured that I could do the timing belt .. I do th rebuilds on my 250f's so I figured. I maybe ai could do the pathy. I do have a ?? for you . Mt front in pops like its ball joints you think it would be the ball joint or the lower arm bushings. ARe thay a pain to replace I have a press???
Purpleone15
I am having to replace my knock sensor but finding different info on location. Has anyone here had to replace one? Can you tell me how to get to it?
atraudes
Car: 2001.5 Infiniti QX4 4WD
For placement/location, check out pages EC-327 and EC-20 in the EC section of the FSM. I don't absolutely know how to get to it, but I'm guessing you'll need to remove all of the intake manifolds/plenums. If someone doesn't pipe up with a good step-by-step on the process, I'd recommend getting the Chilton guide. It proved to be a lifesaver when I did a similar procedure.
Purpleone15
I have the Chilton and the knock sensor is not even mentioned anywhere. That's why I turned here looking for help.
atraudes
This is the one you have, right? Go to page 6-26. I just verified it is under the lower intake manifold.
Purpleone15
Yep. This is the one. Thanks! Found a few other problems going to see about fixing first that are easier to get to. Distributor cap and a elbow piece with a hole in it.
