DaveVQ »
https://forums.nicoclub.com/davevq-u100582.html
Tue Jul 08, 2008 3:52 am
because it allows for an increase in air flow, anything over 70mm is especially noticable when you do it. the pathy TB is 70mm IIRC
Its not a direct bolton though, I believe someone made adapter plates for it fit on both a 5th and 4th gen IM. You should look into and 00VI swap before doing a pathy TB
I'm doing the VH45 (q45) 90mm TB with a VQ35 pathy IM, more airflow means more gas to burn, but more power in the end.
