This 4th of July weekend I decided to take my entire rear-seat back lower interior out of the car so I could apply sound and vibration absorbing rubber roofing material.
Summary: It works!
Problem: Road noise from bad michigan roads and tires which I think are 10k miles to end of life are causing all kinds of headaches when driving with the constant hmmm, rmmmm, bzzzz, especially at 70 to 80 mph.
Solution: You can either use the expensive material which costs about $100 per square yard or go to home depot and buy roof rubber with adhesive backing for about $25 per roll. My car took 4 rolls. I also had some heating/ventilation/duct foam/foil rolls and some accoustic batting.
After taking the entire interior out, I applied the rubber matting. Emphasis was placed on the wheel well area and all flat surfaces. I also applied foam in a cavity adjacent to the wheel wheel. (i'll add arrows later.)
Before
After
Before
After (notice the holes with foam pouring out?) I paid much attention to this side since the sub-woofer sits to the rear of the wheel well.
Before
After (I had to be careful here so that I did not obstruct the air intake for the rear fan.)
Last night, we road tested on Woodward with great success.
Notes: I broke some plastic fasteners and of course the dealers are closed on a national holiday(which the only time to work on cars). Next time I would buy a bag before hand. Also, a roller/brayer is a great tool to burnish the material to the metal body. Cleaning the surfaces also helps. Having a loving wife and eager son also helps.
Today, I plan to address the doors with a new method: double sided rubber mat + sheetmetal strip + rubber mat. This should get rid of the hollow sounding door.
I'll show you in about 2 hours.
