Pathfinder restart issue
jakeanderton920
Car: 2007 Pathfinder LE
I have an '07 Pathy LE and have an issue starting it again after turning it off. I'll turn off the truck, and try to start it again immediately or after a few minutes. It just cranks over, but won't start. I have to let the car rest for 10mins before I can try and get it to fire up. Any thoughts on the issue?
Q451990
:welcome: to NICO! Is your "check engine" light on? When it starts after a 10 minute rest, does it start easily, or is it a rough start? Durning one of these starts after 10 minutes do you notice any smoke from the exhaust?
jakeanderton920
Thank you! No check engine light. Starts right up. No exhaust issue.
Q451990
I did some research, and one thing I saw to try is to press the gas pedal about 1/3 to 1/2 way during the no- start to see if that helps.
jakeanderton920
I have tried this many times and it doesn't help the situation. I am clueless as to what the issue is. Too bad I cannot record audio and upload it so people can diagnose...
