I have an issue with the rear alignment on my Pathfinder, the drivers side wheel toe is out quite a bit, you can basically see it with the naked eye.
I was advised by local wheel alignment guys to replace lower link arm which has the adjustment bush on it, did that but no difference.
Any suggestions what else I may try?
