CudBucket »
https://forums.nicoclub.com/cudbucket-u138774.html
Mon Jul 20, 2009 10:10 am
Hey guys. I'm new to the forum and need some help. I just replaced the power antenna in my 1997 Pathfinder yesterday. The antenna came from a salvage yard. I had to install a Motorola plug on it but it works. Only problem is that it was missing the harness plug for the 3 power wires. I can hard wire it (solder), but the wire colors on the antenna don't match the wire colors in the harness.
The wires in the harness are red, black and red with a green stripe. The wires on the antenna are just black, white and green.
Now, I had taken the bad antenna out years ago so I may be looking at the wrong harness. To the best of my recollection, this is the same harness the old antenna was plugged into. I don't see any other 3-wire harnesses in there. The harness is in the same location as the antenna cable (motorola jack).
Anyway, would any here no how to mate up the different color-coded wires?
Thanks!
Dave
