voolover »
https://forums.nicoclub.com/voolover-u69281.html
Tue Sep 04, 2007 5:22 pm
Well I guess anything is possible. A NEW trans properly installed by the Dealer or reputable shop should not have these kind of problems and, make it right if there is. If, however, you or a buddy did the install, then your on your own.
You state that this is a new unit....is it? I had this very same problem years ago with a non Nissan trans. We disasembled two used ones and mixed and matched shims, shafts and such and made a good one out of the two bad ones....point being.....popping out of gear as you discribe will, 90% of the time, be caused from worn parts or maybe in this case, improperly assembled internal transmission parts...If the pressure plate got beat up in the process of assembly, it would be hard or even impossible to shift.
Is the shop trying to say that something else is causeing this??
