Pathfinder Noise when reversing
Craig Batten
Car: Nissan Pathfinder YD25DDTI (RHD Model)
Year 2011
Has anybody experienced strange noises coming from the back wheels or drive train when reversing their Pathfinder. I experience it, but it does not happen everytime i reverse.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Can you describe the sound further? Is it a clunk, a squeak, ???
Welcome to NICO.
Craig Batten
Year 2011
To be honest it sound like the brake catching and then releasing. I've had three different mechanics inspect the back and they've all said everything looks in good order.
Towncivilian
Have you tried greasing the driveshaft? There are reports of strange noises going away afterwards.
Slumpert
Car: 1997.4 Pathfinder
Could also be rear joints are worn and allowing change of angle on the drive shaft.
A wiggle with mechanics hands is not the same stress putting it into gear and moving. 4000 lbs.
Craig Batten
Year 2011
Thanks Guys, I will look into these options, many thanks. Will give feed back.
