pathfinder is over heating
Stauffed
Car: 2003 Nissan pathfinder chilkoot
Hi, I'm hoping someone might have some insight for me. My 2003 chilkoot is bubbling out coolant, it has heat when I'm driving but stops blowing heat when I'm at stop light. I checked oil to make sure that there was no coolant in there and checked rad to make sure there was no oil in there. Like I said any help would be appreciated.
Thank-you
dareno
Car: Pathfinder R50, 3.5 l V6 LE
I had the same issue the first winter I bought it. I had to bleed coolant system.
I remember I had to park the car on an incline so the front is much higher than back, then open coolant main reservoir (remover metal cover) and a bleeding hose behind engine.
Engine is running and air bubbles should come out/
https://www.youtube.com/watch?v=REjYjiO8xIs
