Pathfinder idle problem
06pathyman
Car: 2006 Pathfinder LE
Hey you guys,
I'm appealing to the Nissan gods again. I have a 06 pathy with less than 50k When it idles it seems to idle down far and starts to vibrate... Seems like it might have something to do with voltage because if I pull up on the window switches to raise the windows with them already up, the voltmeter on the dash drops some and the engine bogs down. I need to get a voltage tester and see if the alternator is in fact loosing voltage or amperage. Any help would be great. Thanks you guys.
mtbmikeg100
Car: Infiniti FX 35 sport & 2008 Nissan Pathfinder SE
I had the same issue. With my 08 Path. I felt as though it was the same issue that you describbed. I took it into my local mechanic and he said it was a dirty throttle body. Sprayed some cleaner in side, and cleaned all of the black residue off. It was getting stuck and not popping back into place after I released the pedal. Hope this helps.
06pathyman
Thanks a lot I'll try that ..
ranimouf
Car: qx4 2001
I have a 01 qx4 which was leaking oil.The shop replaced valve gasquets and they had to do it twice because it was still leaking .when i took the car home it was vibrating .The next morning as soon as I started the car ,it vibrated alot that it almost shut off, but vibrated less when the engin got hot . I told the shop ,and they kept saying That i need to clean my fuel injector .I told them that the problem started when they worked on the car ,but they would not admit it. later on I had to take it back because I started hearing a strange loud noise coming from the rigtside of engin which I knew it was a massive air leak . It turned out that they cracked an intake hose when the removed the intake twice.They replaced the hose and the car started idling fine now.hope this helps
W O T
Car: 2001 Infiniti Qx4
Dont vacuum leaks only cause the car to idle HIGHER though?
06pathyman
Cleaning the Throttle body fixed the problem.. Thanks Alot !!
