Pathfinder ATF oil
Ammar738
Car: Nissan Pathfinder 2004
Hello dear
I have pathfinder 2004 automatic
Type - MPV
ENGINE - VQ35 (DE)
The question is
How many oil liter change for automatic transmission fluid (capacity)?
Thank you for help
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
http://www.nicoclub.com/FSM/Pathfinder/ ... der/at.pdf
Page 353,
A/T fluid capacity:
8.5 liters / 9 Quarts
Ammar738
Thank you for your help
yeldogt
Car: 02 Pathfinder 4X LE (X2)
I believe when you drain the pan -- 4 quarts comes out. My memory is I bought a case of 6 quarts and had enough to do the simple fluid drop and same for the transfer case. Nissan D matic.
AlanAZ
Car: 2003 Infiniti QX4 RWD
yeldogt wrote:I believe when you drain the pan -- 4 quarts comes out.
If you jack the right front corner (on the sub-frame), you can get an additional 1 qt out, since the drain is rear left.
Ammar738
So !!!
AlanAZ
So, instead of draining 4 qts (out of a total capacity of 9 qts), you're draining 5 qts by significantly jacking the front corner. Win !!!
