heelsrtops wrote:
I don't know how they determined the gear was bad. I'll ask when I go to pick up the QX4. I kind of had to prod them to spend more time on the axle so I can't imagine they did anything more than the basics you mentioned.
Yeah, I'd definitely prod them about how they reached that conclusion, especially without draining the fluid (which I would've expected that they charge you for if they did), or putting it on a lift and spin some tires by hand (and then demonstrating the test to you). It absolutely blows my mind that a mechanic can propose a $2000 solution, charge $100 for reaching that conclusion, and not do $5 worth (let alone $100) of work to prove it. They might be right at times, but it's like saying the truck rumbles because of the position of the moon when you happen to be driving and you should get it fixed immediately otherwise every puppy in the world will die. (All, of which, is true, btw.)
I've got some other responses regarding the diff swap and JY questions lined up for you, but first: if I were troubleshooting this, I'd actually be checking out the driveshaft, the transmission mount, and the motor mounts before even remotely considering the rear end. The driveshaft always rotates 4.363 times faster than your ring gear or tires do, and an off-balance driveshaft (it's no small piece of steel) will vibrate your entire driveline (t-case, transmission, axle)...and a bad transmission mount will promote it.
Although the amount of work to swap the diff is rather straightforward in my opinion, but the amount of work to test the driveshaft is trivial in comparison: 20 mins and a 14mm wrench. The transmission mount can be eye-balled for cracks, and even a crowbar can expose any failures. Doesn't hurt to also torque the bolts down while under there.
Money being an object, that's how I would start. $0 test, along wth rotating the tires. If a JY driveshaft is cheap enough (any 4wd AT 3.5L should fit), I'd even swap that in as a simple test. But otherwise you could take the driveshaft to any drivetrain shop and they can have it balance tested and fixed in minutes for a nominal charge.
Also, would you say that you feel the rumbles as you're accelerating, or just when you settle at a speed range? A diff issue would present itself at all speeds, and because it has a very low tolerance for error, these typically produce some noise (like a one-time clank or a prolonged whine/hum/screech/clicks) before catastrophic failure. Have you had any event where an object may have struck the driveshaft by chance?
Beyond that, I'll gladly provide any details you need for the diff swap if you decide to go that route. I can even mock up the process via video if you think it'll help. I'd hold off on the axles shafts. Under very extreme circumstances would you ever need to replace both...like if the spider gears grenaded and damaged the splines. Even then, needing to replace just one axle shaft is usually warranted by some known event (like a collision, getting seriously stuck while 4-wheeling, falling off cliff, etc.).
